Status
Not open for further replies.
1 - 2 of 2 Posts
Hi,
I recently bought a 30 inch CRT HDTV and progresive scan dvd player and now looking to buy HT(not much expensive since living in apartment)..so i am checking on web sites and i found reasonable HT for
I can't comment on the items you listed, but the receiver does not have to have component inputs to still be able to use component cables. The benefit on having component inputs on the receiver is that you can hook everything up through the receiver and you will never have to switch inputs on the TV. I fyou don't mind switching the receiver to DVD, and then changing the TV input, then you don't need to worry about component inputs on the receiver. Some have even noticed a drop in PQ when going through the receiver instead of a direct connection from the DVD player to the TV.
1 - 2 of 2 Posts
Status
