1 - 20 of 20 Posts
Discussion Starter #1
So I recently picked up a Denon AVR-X3000 for ~550 on eBay refurbished. Now I've been in a long, arduous research struggle trying to find a good speaker system to go with it. I would probably go with a 5.1 setup even though I have a 7.2 receiver. And, without a doubt I want the rear speakers to be wireless. I'm looking to spend $7-800 So as you can imagine the search hasn't been easy. Anyone have any suggestions? Thanks!
My suggestion would be to get two nice towers or two decent bookshelfs and a good sub and hold off until you can afford the rest.
A fairly good subwoofer costs $700-800.
Your price range is very limiting; you can't go very far with that.
There is one fairly decent starter system that you can get, though; the Martin-Logan MLT-2 system. Amazon has the discontinued version now for only $350. That is a very good deal for the money. It was a good deal when it was $600.
The Jamo S426 HCS3 5.0 speaker system is also at Amazon for $369; another very good deal. add a Polk PSW505 subwoofer for $240 and you will have a fairly decent setup.
You won't find much better for under $800.
Originally Posted by commsysman  /t/1515229/need-advice-on-purchasing-speaker-system-to-go-with-denon-avr-x3000-700-800#post_24294097
I got that Jamo 426 system for $129 at Amazon.. and at that price it is not really that good, at $369 it is definitely not a good deal, I returned it.
i would get the AJ Pioneers before that.
But this is much better...
X4
http://www.htd.com/Products/level-two-speakers/Level-TWO-Bookshelf-Speakers
center
http://www.htd.com/Products/level-two-speakers/Level-TWO-Center-Channel-Speaker
a review,,
http://www.hometheatershack.com/forums/speaker-subwoofer-reviews/68348-home-theater-direct-htd-level-two-system-review.html
sub..
http://www.parts-express.com/dayton-audio-sub-1200-12-120-watt-powered-subwoofer--300-629
a review...
http://www.hometheatershack.com/forums/speaker-subwoofer-reviews/71766-dayton-audio-sub-1200-subwoofer-review.html
And get a wireless transmitter and receiver for the back...
Discussion Starter #6
Originally Posted by mark62  /t/1515229/need-advice-on-purchasing-speaker-system-to-go-with-denon-avr-x3000-700-800#post_24295157
X4
center
a review,,
sub..
a review...
How's that work?
Discussion Starter #9
Originally Posted by real1g  /t/1515229/need-advice-on-purchasing-speaker-system-to-go-with-denon-avr-x3000-700-800#post_24292647
How big is your room and what are your listening preferences?
Originally Posted by real1g  /t/1515229/need-advice-on-purchasing-speaker-system-to-go-with-denon-avr-x3000-700-800#post_24296385
Oh these are actually good? I thought they'd diminish the sound quality.
Any wireless speaker you buy is going to have the same thing basically.
Discussion Starter #12
Originally Posted by bladerunner6  /t/1515229/need-advice-on-purchasing-speaker-system-to-go-with-denon-avr-x3000-700-800#post_24296919
It's 20x14. The tv is going on a 7ft wall and the couch will be 11ft away. I enjoy movies if that's what you're asking.
Originally Posted by real1g  /t/1515229/need-advice-on-purchasing-speaker-system-to-go-with-denon-avr-x3000-700-800#post_24297227
That was what I was asking, thanks.
That is not a huge space, but having the Cambridge towers might be nice.
I agree with what a couple others have said, $700-800 for a 5.1 setup with wireless surrounds, you will never be completely satisfied with it. "The bitterness of poor quality remains long after the sweetness of a low price is forgotten" Get a decent pair of fronts and a sub for now, Arx A1b's and the SVS PB-1000 was a good suggestion, then gradually add on a center and surrounds as you get more money.
I would agree AND disagree. Agree, get a 2.1 on that budget. Disagree on towers! Get a quality bookshelf pair (ascend acoustic 170s, perhaps) and a decent sub. The ascend are 350/pr and that would leave you 350-400 for a sob. If you can stretch the budget any, the svs pb1000 is a really good sub for 500 dollars.
Discussion Starter #17
should i start with bookshelf speakers or floor standing speakers. going to start with 2.1 and work my way up. Thanks!
Originally Posted by real1g  /t/1515229/need-advice-on-purchasing-speaker-system-to-go-with-denon-avr-x3000-700-800#post_24325286
bookshelves will be fine, usually at the same price point the bookshelves can be better than towers. When you crossover at 80hz to a sub that negates the lower frequency cutoff of a tower.
Just remember to include stands in your budget, then again the cost of the stands can raise the cost to a better pair of towers.
bookshelf
Originally Posted by Elihawk  /t/1515229/need-advice-on-purchasing-speaker-system-to-go-with-denon-avr-x3000-700-800#post_24297960
Originally Posted by zieglj01  /t/1515229/need-advice-on-purchasing-speaker-system-to-go-with-denon-avr-x3000-700-800#post_24325381
bookshelf
+1 Also FWIW, the Ascend CBM-170's are currently on sale for $300 a pair. Both those and the SVS pb-1000 would be solid, long term purchases
1 - 20 of 20 Posts
