I've spent a lot of time viewing various HDTV's in my local electronics retailers and I've decided that the Sammy DLP's have the best PQ IMHO.
I'm trying to decide between the HLN467W & the 567W. At first I was going to go with the 46 as it would fit in my current wall unit with little modification, but then I started thinking about the advantages of the larger screen. My viewing distance is about 9' & I will be using Comcast Cable with a Motorola 5100 STB (No DVI yet unfortunately). After reading many posts I have some concerns about SD reception. None of the retailers (Best Buy, Circuit City, etc) had the units equipped to show me an SD picture (go figure). All of their HDTV's were running either HD or DVD's. I'll still be using my Tivo to record SD & I'm a little worried about spending thousands on a new HDTV and being shocked by a poor SD picture. Hopefully some current Sammy owners could give me some input on this if possible. Does the 46 make more sense because of room size & a possibly less grainy SD picture, or should I expect minimal difference between the two and go for the 56? Having never seen any SD on the Sammy, maybe I'm overreacting & the picture isn't that bad? Please help.
