1 - 1 of 1 Posts
I need a little advice on how to go about sound proofing the door. The opening into the theater will be over 20" deep, so I was planing to run the clips on all 3 sides, then screw the door frame though the drywall/OSB into the framing on the outside or just into the OSB? (the framing on the left in the picture). So, when entering the theater the door is flush on the outside, but from the theater side, there is a recess. I can't have the door opening inwards, need the space for seating.
Thanks guys.
1 - 1 of 1 Posts
