Status
Not open for further replies.
1 - 3 of 3 Posts
Hi, I would like to get a universal remote to run two ReplayTV units and a television. The only thing I require is that it is backlit. I don't need a super duper fancy smanshy remote control!! Does anyone have a suggestion?
TIA
Aloha
one for all or radio shack remotes
To run two different RelayTV units you willl need an OFA remote that is JP1 capable and the JP1 cable and a Windows PC. The Robman is the resident expert on Replay and, for that matter, just about everyting else in the OFA /JP1 world.
There are two remotes that I would specifically recommend the URC-8811 aka as an 8810w in some WallMarts and the Radio Shack 2116 (the 2117 is similar and has an RF capability as well and was being sold for the same price as the 2116 -- $30)
JP1 cables are about $14 the software is free.
Start at www.hifi-remote.com and follow the links to JP1
BTW, it's not hard and there is a very active support group.
-Jon
1 - 3 of 3 Posts
Status
