Don't know if it's inexpensive enough for you, but
http://www.220-electronics.com/ is selling a hacked JVC 500 for ~$180. That's a pretty good price for such a beast. No chroma bug. Decent film-mode deinterlacing, especially if you force film mode. Generally well liked PQ although maybe a tad softer than your XP30. Secret's reviewed older versions of JVC players, which pretty much had the same guts and design.
OR if you really want to go cheap, give the Cyberhome 500 a try. They run ~$80 at Best Buy. You just need to do a remote hack to get region-free playback--I believe it comes w/ PAL->NTSC already enabled. People on a tight budget seem to love it although its PQ will likely pale in comparison to your XP30. No chroma bug. QC and reliability are quite questionable as can be expected w/ a budget player from a no-frills maker. Was also reviewed by Secret's.
_Man_
