1 - 8 of 8 Posts
· Registered
Hi all,
Currently I have an AntennasDirect DB2 which works well for getting all the UHF channels in my area. However there are two channels I'd like to get which are located on VHF 6 and 13. My tvfool results are here:
tvfool.com/?option=com_wrapper&Itemid=29&q=id%3daead770f230764
All the VHF antennas I've found so far seem to be optimized for 7-69 - not 1-6. Are there any that are optimized for both 1-6 and 7-13?
Also, would it be more cost effective to just get a combo UHF/VHF antenna instead of getting a dedicated VHF antenna and a combo adapter? The signal is going to go to three TVs, FWIW. Thanks!
· Banned
This will work fine:
http://www.solidsignal.com/prod_disp...p?prod=HD-7010
You can aim your old antenna at 106 for WNJS. Add them together with a backwards splitter.
I believe that your high VHF is WHYY on channel 12.
· Registered
Nice find Project! I agree, the C5600 is a great choice given the very high signal strength in the OP's area and the identical tower orientation for ch 6 and 12. The OP could continue to use his db2 for UHF and acquire VHF with the C5600. The two antennas could be joined with a usvj joiner for a single downlead to the tv(s). Mount the DB-2 on top and space the two antennas about 4 feet apart.
· Registered
Discussion Starter · #5 ·
Thanks for the recommendations everybody! I will check out the Winegard and CS600. I was also thinking about the HD7082p since it claims to have a 6.2db gain on channel 6. But of course it is almost four times the price of the CS600...
· Registered
If the TVfool forecasts are to be believed (and there is no reason not to), you have PLENTY of channel 6 signal and more gain isn't necessary. A simple dipole should be sufficient to receive that signal.
However, you may need some directionality in the case that multi-path is present.
Have you tried a simple channel 6 dipole outdoors? A cheap FM radio antenna (a couple of bucks) is close enough for 6.
· Registered
Hi all,
If you like to tinker, for around $5 you can try building this.
http://www.hard-core-dx.com/nordicdx...wire/t2fd.html
1 - 8 of 8 Posts
