1 - 2 of 2 Posts
Hello All,
I have recently set up my 3.1 system but I am having problems getting the audio from my PC. Currently, I have my PC running a DVI to HDMI cable with the input selected as HDMI 2 on the receiver. I fear that it will only run the audio from the HDMI cable but this is not possible as the PC is connected through its DVI port. I have a 3.5 mm to RCA for the audio from the PC but any RCA (PC used to be connected and audio played through TV) connection will not play through the HDMI input on the receiver.
Is it even possible to have analog audio out with the HDMI input on the receiver? If so can anyone help?
THANKS!!
gee... i wonder if it's possible...
if you look in the official 1020 thread , you'll see that "someone", within the last hour, posted a solution to your problem...
suggestion: start in the official thread with your questions, rather than starting a new topic...
1 - 2 of 2 Posts
