1 - 2 of 2 Posts
· Registered
Does anyone have any suggestions to get a built-in HD and built-in bluetooth car receiver? I have found some that are either bluetooth or HD built in and the only one that sells them both is DUAL XDH 7714 which through various forums I have found has poor sound quality
I am a big fan of Kenwood or JVC receivers from past experiences
Many Thanks
PK
· Registered
I'm in the same boat as you. I've been looking at Alpine, because they just have a good reputation. You might want to consider something like the Alpine CDA-105 with the optional HD tuner unit and BT unit. That will cost you around $500 before installation though. Sure the Alpine units sound expensive, but the Parrot based Bluetooth units sounds like the ticket to me. From reading a bunch of reviews it sounds like the there are still a lot of rought edged around Bluetooth phone integration.
The Dual units seems like such a deal, but their tuners are getting a bad rap.
I'm actually thinking of blowing off the HD radio and just getting the Alpine CDE-102 with the Bluetooth and iPod kit for around $330 before installation.
1 - 2 of 2 Posts
