Need Cheap DVD Audio/SACD player.
2049 Views 21 Replies 11 Participants Last post by  hotguy8289
I have a good DVD player (zenith 318) and need a decent DVD-A and SACD in one player for audio only. Im not looking for high end stuff, and Im hoping to spend under 200. I think both of these formats are gonna die anyway with HD/Blue Ray coming by the end of the year. My main reason is I want to get a player is for the NIN The Downward Spiral and The dark side of the Moon. Im sure there are other great titles to get. Any opinions would be appreciated. How is this player: Pioneer DV-578A-S. I can get one for about 130
Status
Not open for further replies.
1 - 20 of 22 Posts
I have the older model Pioneer 563 and I love it. With decent speakers and using an SPL meter to calibrate your system you should do well with the Pioneer 578. With the future so uncertain for DVD-A and SACD I would not buy an expensive player.
Some people may disagree with me but I think the Pioneer player is awesome for the price. I bought mine in the Fall of 2003 and I paid $180 for it. This was the best $180 I've ever spent.
The Pioneer is probably the best you can get at your price point. If you're willing to stretch to around 300$ (I've heard street prices are closer to 270$), you might consider the Yamaha C750. It's universal, has flexible bass management (which the Pioneer doesn't) and is a carousel. It was recently reviewed at Audioholics and got a great review. Performance with redbook CDs was particularly praised, so even if the hi-res formats don't pan out for you, the CD playback alone might be worth the money. After that, you start looking at around 500$ for universals, of various quality/features.
I'd recommend the Samsung over the Pioneer - at least the 563a player. The 563a has a bug that does not allow it to play DVD-A titles by Rhino and (I believe) Universal. The Sammy 841 plays everything I throw at it and I'm sure you can get it for a good price. Though it does have DVI out as well and therefore may run a bit more than the Pioneer for that feature, but so many people have returned them for DTS issues and DVI black level problems (which won't matter to you anyway) that you should be able to find an open box one at a great price.
And FWIW (though haven't seen the Yamaha C750) all the cheap players that I am aware of do not do bass management very well (large setting - all bass goes to the speaker except .1 channel, small setting, the player is preset at a crossover level -for the Pio 563 it is 200hz for DVD-A and 120 hz for SACD). If your receiver does not offer Analog bass management, you may need an external device like the ICBM from Outlaw audio. I bought one (originally for the Pio 563a) and it made a world of difference. However, I went the the Sammy 841 as I wanted the DVI out and universal capabilities, as well as the fact as previously mentioned the Pio 563A does not play Rhino Discs without hiccups (the sound cuts out, it starts about 15 minutes into a title and increases in both occurences and lengths as you listen to the title longer).
As for a fix -I have emailed Pioneer customer service numerous times and have never heard back from them. I doubt I'd ever buy another Pio product again (my last purchase was a Tohsiba RD-XS32 HDD DVD burner, would have bought the Pio 520H but now you know why I didn't! :)).
See less See more
I like my 578. Mine is also "audio only" solution. Given its limitations, its a good low cost solution. I agree, with HD on the horizon, its probably not a good time to spend big money on these players.
Search Dealtime (search box located on this webpage!)... you'll find a 578a for 20 bucks less than your price, delivered... and a 841 for another 10 dollars cheaper than that!
I dont disagree with you. For the $150 or under pricepoint, the 563 and even the 578 are great bargains and excellent performers. Anyone that expects it to perform like $400-$500 uni's is deluded. This is where I think it is getting a bad rep. I dont know what some people expect for under $150?
I have a 563, and after the firmware upgrade to 1.906, it plays everything....
See less See more
I love my 578a. I upgraded to it because of The Downward Spiral. I then bought both the SACD and DualDisc of TDS. Awesome. I'm hoping for Pretty Hate Machine and The Fragile to be remixed and mastered.
I also have the 563 and need the upgrade. I understand you have to send to a Pioneer service center. May I ask how long it took them to get your unit back to you? I'd like to have some idea of how long I'll be without my player.
3 days....
There is an authorized service place less than 20 minutes from my house...you can look them up at the pioneer site. My player was only about 6 weeks old, I called Pioneer, they said just call and take it in. My understanding is that firmware upgrades are covered for 3 years from date of purchase, regardless of the 90 days or 1 year on everything else in the unit.
Call Pioneer customer support USA:
1-800-421-1404 option 2, option 6
I dont know why anyone would wait to get this done, or at least spend the 5 minutes to figure out where they can send it, and how long it would take?
So after you get the nearest service place, you call them to get their time frame.
See less See more
Thanks for the info. I assumed it would have to be shipped to some remote location where it would sit for weeks/months. From my previous experiences with getting electronics serviced I expected at least 2-6 weeks.
My 563 wouldn't play Gaucho and Goodbye Yellow Brick Road. I sent my unit to an outfit in Fort Dodge, IA (BFE). From the day I sent it until the time it was delivered back was exactly 4 weeks. But, as was mentioned earlier, now it will take any disc I throw at it. Upgrade now!
I have the Sony 775 DVD/SACD player, bass management is dreadful (fixed 120 Hz xover, no redirect from LFE to large).
Could anyone steer me towards a budget choice w/ better BM options, like lower or adjustable xover and/or redirect sub to large? I'll pay more for such a player, say >$400. DVD-A is optional. Thanks to anyone who can help!:)
Problem is (or was) here in Canada no one was recognizing the problem (from Pioneer) and didn't know anything about an upgrade.
Besides - that to me is still very crappy service.
Samsung - they just released a 'fix for DVI' for their 841 players. My guess is they won't 'recognize' their 'problems' either - but I DOWNLOADED it, burned it on a CD. loaded it in my player, and 3 minutes later the Samsung works perfect (regarding DTS dropouts and IMO the blacks via DVI are better now to - but impossible to do an a/b comparison).
If Pioneer was good, they would offer the same upgrade as Samsung did, rather then me having to send my player away for a simple fix.
But hey - if you guys like the PIO so much - pm me, I'd gladly sell you mine at a good price (it's boxed up, sealed and in storage right now).
See less See more
How about $199 (bstock) for an Outlaw ICBM? I use one (originally bought it for my Pioneer 563a and use it with my Samsung 841 now).
What you do with it is instead of plugging in your analog cables into your Receiver, they go into the ICBM. The ICBM has outputs to your receiver. You set you speakers to LARGE in the player so the full range goes to each input of the ICBM. The ICBM has dials for the front L/R, Center, surround L/R, and Rear (which can be split - if you have a rear). As well it has a volume control for the LFE, and a volume gain for your sub.
The cross overs are set at 40, 60, 80, 100, 120, and off. The ICBM will direct all the LFE, along with any bass below the cutoff points you have set to your sub. I haven't seen all the high end players out there, but from what I understand the ICBM is the most flexible device you can get for analog bass management and at least matches but most likely exceeds any thing else out there! Plus, it's a lot cheaper than buying a $600 + player or a new receiver that does analog bass management.
Check it out - two big thumbs up for this here! A very cheap upgrade for what you gain from it.
See less See more
The only thing as flexible (or more) that I've come across is my receiver's MCH BM/TA. I can select from 40, 60, 80, 100, 120, or 150 hz AND apply the same speaker delays as are set for DD/DTS. It does, however, require an A/D/A conversion--which the ICBM does not. The ICBM does NOT address the speaker distance issue, though it is a MUCH less expensive solution than buying a receiver just for that purpose (I was buying a receiver anyway, and this feature was a major selling point for me, but if I already had a receiver, an ICBM would have been my first choice).
Originally posted by Kpt_Krunch
(Snip)Samsung - they just released a 'fix for DVI' for their 841 players. My guess is they won't 'recognize' their 'problems' either - but I DOWNLOADED it, burned it on a CD. loaded it in my player, and 3 minutes later the Samsung works perfect (regarding DTS dropouts and IMO the blacks via DVI are better now to - but impossible to do an a/b comparison).
How do you do the upgrade? The Help file (in PDF) about upgrading left out a pertinent detail - what kind of CD do you burn the files as? Data or Audio CD? And can it only work with PC downloads?
For those who want to know about the Samsung DVD-HD841 upgrade, click here.
So does this fix the black crush problem on the Samsung?
fuad
See less See more
fuad
I used Nero and copied it as a 'data CD'. It's rather simple actually, took less than 30 seconds to burn, and about 3 minutes to load in my player. There are two files, I loaded them in the same order as they unzipped in the download :
build.img
update.ver
As for Black crush - I have the player hooked up via component and DVI - when looking at a star field (space scene) I cannot find any 'missing' stars on the DVI as compared to the component, and the DVI stars seem a bit brighter (it could be though just because the picture on the DVI is much more detailed and sharper since it is set to 720, which is the native resolution of my set).
I don't know why Pioneer doesn't offer the same type of service - sending a player away for a simple (?) fix is a waste to me.
See less See more
Okay, Samsung USA has four Hi-Def Conversion players.
HD-841 is DVI out only with DVI-DVI cable as part of the cables given.
HD-941 is HDMI out only with HDMI-HDMI and HDMI-DVI cables as part of the cables given.
HD-850 is DVI only with DVI-DVI cable, but it is not a universal player.
HD-950 is HDMI capable but I guess it's not released yet.
So here's my question : does the 941 is basically the same as the 841 but with a HDMI output? As in same black crush problem (which I guess is fixable using the same upgrade method) but via HDMI? And does it mean it can digitally output DVD-A and SACD digital audio signals to a HDMI capable receiver?
fuad
See less See more
fuad - I don't own the 941 - and it is not released in Canada yet. But from what I understand, the 941 has the Faroudja chip in it (the 841 does not- but that's no never mind to me as my Samsung DLP HLN model has it anyway) and black crush when going from HDMI to HDMI is eliminated, but if you need a DVI connections - HDMI to DVI - I believe I read that the BC then shows up (that doesn't make sense to me, I'm only going by what I have read though, not what I have seen personally).
I haven't seen or read anything on the 850 - but since it is not an uni player I wouldn't be interested in it anyway.
You're right. It is crappy service. It's the way of the world though. For everyone that says, "I'm not buying your crap anymore." There are ten people lined up behind you just to buy their crap. They don't care. Anyway, heres a link to Pioneers page regarding their little "issue" with the DVD firmware. Canada is listed there too.
http://208.220.235.52:7001/eSupportJSP/SolutionFind.jsp
1 - 20 of 22 Posts
Status
