Hi all - I'm hoping you guys can help clear up some confusion for me about how my Yamaha RX-V1400 works with regards to its speaker output options and bass.
I'm trying to fully understand the relationship between the Large vs. Small option, the LFE/Bass Out option, and the crossover frequency. I called Yamaha tech support but based on what I see in the manual they told me wrong info. Hopefully you guys can help me get this straight.
Here is what the Yamaha manual says for these options:
SMALL vs. LARGE:
- Select Large if you have a large xxx speaker. The unit directs the entire range of the xxx channel to the xxx speaker.
- Select Small if you have a small xxx speaker. The unit directs the low-frequency signals of the xxx channel to the speakers selected with "BASS OUT".
(substitute left/center/right where I have xxx above)
LFE/Bass Out
LFE signals carry low-frequency effects when this unit decodes a DD or DTS signal. The low-frequency signals can be directed to both left and right speakers, and to the subwoofer (subwoofer can be used for both stero reproduction and the sound field program).
Choices: SWFR, FRNT, BOTH. THX recommends SWFR.
Select SWFR if you connect a subwoofer. The unit directs all LFE and low-frequency signals to the subwoofer.
Select FRNT if you do not connect a subwoofer. The unit directs all LFE and low-frequency signals to the front speakers, even if you previously set the front speakers to small.
Select BOTH to direct LFE signals to the subwoofer. Other low-frequency signals are directed to both the subwoofer and the other front channels in accordance with your other speaker settings.
CROSS OVER
Use this feature to select a crossover frequency for all low-frequency signals. All frequencies below the selected frequencies will be sent to the subwoofer.
QUESTIONS
1) Assume I set all my speakers to small, the LFE/Bass Out to SWFR, and the crossover to 80hz. Now a 60hz signal comes it for the left channel. Am I correct that the the 60hz for this channel will not play from the left speaker but rather it will be redirected and play out of the subwoofer?
2) If I had my front speakers set to Large instead of Small, am I correct that the 60hz signal would not be crossed over, and the entire signal would be played out of the left speaker and nothing for it sent out of the sub?
3) Am I correct that the crossover frequency serves as a cutoff point, but only for speakers marked as SMALL? So in other words speakers marked as Large ignore the crossover completely, and for speakers set to Small the crossover is the point at which the cutoff occurs for that speaker?
4) The Yamaha tech rep I spoke to told me that if I set my front speakers to small but still want the low frequencies from those speakers, that I MUST set my LFE/Bass Out option to BOTH. He said he was positive about this. He went on to say that otherwise the low frequencies below my crossover for the front speakers would be thrown out and lost completely (not played through any speaker).
He went on to say that if I have the "LFE/Bass Out" option set to SWFR, then the sub will ONLY play LFE channel information.
THIS MAKES NO SENSE to me according to the manual. If I'm reading the manual correctly it clearly states that with the Bass Out option set to SWFR, the low frequencies from the other channels get redirected to the sub based on their settings (I assume this means its redirected only if those speakers are set to Small). This completely contradicts what the tech told me. I am confused - which is right??
5) My understanding according to the manual is that if I have LFE/Bass Out option set to BOTH, that it will send LFE information to the front speakers (contrary to what the tech told me). Is that right? If so I would never want to do this.
Overall I plan to set all my speakers on Small, the LFE/Bass Out option on SWFR, and the crossover to 60-80hz. My main concern is that I want the subwoofer to help out the fronts and surrounds with lower frequencies that are not in the LFE channel. Would these settings then be correct?
Thanks - I appreciate any info that will help me sort all this out!
SMALL vs. LARGE:
LFE/Bass Out
CROSS OVER
QUESTIONS
