I've been a strong proponent of LCD panels - and have bought a few 30" and 37" Aquos panels for around the house - but through an ironic twist of fate I have been using an old 32" Sony Wega CRT in my home theater. Eww!
Well, time to remedy that. As noted, I am a fan of LCD for all the right reasons for me, among them that my other panels are on literally 18 hours a day, in bright rooms, wall mounted, with mostly static images (nuff' said!)... but in the case of my home theater, it's for movies only, so it will only be on a few hours at a time, in a darkened room, and does NOT need to be wall-mounted. So all-in-all, I think plasma is a good choice here. Oh, and it'll cost 1/3 of an equivelent LCD, which is a bonus that I'm usually willing to "overlook"
Okay, background aside, here's my dilemma: my cabinetry is 40 1/16" wide - plus or minus 1/16" depending upon seasonal humidity (wood swelling).
I'm looking at the Panasonic 42" because I'd like to go bigger than 37", but I think it'll be tight. The Panny spec says, "Width = 40.2" (Has to be the commercial version 'else the speakers ruin the width for me).
So anyone who has a 42" Panny - ideally the TH42PWD7UY - can you please give me an exact, real-world side-to-side width measurement of your set. I stopped by BB tonight to sneak a measurment, but they didn't have any, and I'd like to order this from PC or VA soon.
Many, many thanks!
Jcd
PS: Since I'm here, do the commercial versions typically have the "shut down issue" reported elsewhere?
Many, many thanks!
Jcd
