Ok, long story short, I just purchased a new TV stand for the 65" plasma that's coming Friday. The stand is enclosed with glass doors. Between the TiVo, BluRay, and Amp, I can tell it's going to be too hot with the door closed (TiVo temp around 47c open, went up to 52 after about 90 minutes closed).
Here's the trick. I had to cut a pretty large cutout in the back panel (about 3" high by 12" wide) to allow the amp to fit with the plugs and such. The amp sits on the bottom shelf, with a TiVo and BluRay on the upper (there's about a 1" gap at the back of the shelf for wires and such). With that large of a hole, would I be able to just pop a 120mm fan in the upper portion to exhaust some heat? Or would I still need an intake fan as well since both the hole and the fan are in the back panel?
