1 - 3 of 3 Posts
Im setting up my HK reciever's crossover settings. I have Atlantic Tech. FS32000 for my L,R,C they are rated at 75hz-20khz. Im setting the crossover for 80hz.
My sides and rears are polk audio rm 3000 which are rated 25hz-20 khz.
What cross over should they be set to ? I was just going to keep all settings to 80hz and let the sub pick up under 80hz.
Also I have a setting on my HK 635 for LFE LP FLT its set at 120hz currently should this be set to 80 hz as well ?
Thanks Tony
Experimenting is the only good advise you will get, crossover settings vary from room to room, and from equipment to equipment, yes there are "standard" 80hz from DD, but it does not apply to all setups. Mine for instance are set at 65hz, and that is how I get the best integration.
Play with settings until you find what works best in your room.
Sorry, I couldnt be more helpful, but trial and error will determine whats best for your setup.
1 - 3 of 3 Posts
