need dwin ld-1 ld-2 remote
375 Views 6 Replies 4 Participants Last post by  nerbe
i need a remote for a dwin doubler, please email me if you have one available. thanks, ken
Status
Not open for further replies.
1 - 7 of 7 Posts
Have you checked with Dwin to see if they can sell you a new one? They used a older model Zenith universal remote with these line doublers. If you can't find one, then I could probably help you out by programming one of the One-for-All universal learning remotes (e.g., Cinema 7) for use the Dwin line doubler. I have done this for operating my LD1 as well as the other home theater equipment in one of my systems.
If you happen to have a Philips Pronto remote then the codes for the Dwin could simply be downloaded.
Ron Jones
[email protected]
i emailed them last week and havnt heard anything back. i have a learning remote that came with my denon, but need an original to program it. might have to look into a pronto. thanks for the input, ken
I have an LD-1 or 2 processor and remote (I'm out of town now and don't remember which one). If you can't locate one I could lend you mine so you could program a learning remote.
BTW, I would like to sell my unit (was working fine when I upgraded my projector) if you know of anyone interested.
Neil
is yours a LD-1 or 2? it seems the remote is in fact a allegro 400 or 500 also branded as zenith. i talked to dwin ( they never answered the email i sent ) and they say the code for the ld-1 or 2 is 133. the only info i found on a allegro/zenith was at remotecentral.com and it looked like thier codes are the same as several cheap tvs, so i attempted to use a newer RCA and prorammed it to all codes that matched the tvs listed for 133 on RC.com and no dice. I may be interested in your LD-1 or 2, email me directly at [email protected] . thanks, ken
Hi kenolle,I have a new Gemini universal remote on hand that I purchased several years ago before selling my LD-2 because it seemed identical to the supplied remote,I think I programmed it to the LD-2 using learning mode but I cannot remember maybe I put it in Auxiliary mode.E mail me at [email protected] and send me your address and I will mail it off to you for testing.If you find that it works for you it is yours for the postage. Tom.W :)
I have an LD-2, remote and documentation that I would like to sell. Not sure what it's worth (probably not much) but if anyone wants it let me know.
Neil
1 - 7 of 7 Posts
Status
