Well, I'm counting the days until my HD TV gets delivered (6/30), so in the meantime, I want to get my antenna installed. I already have the STB, so I can get the antenna completely set up before my new TV arrives.
I'm in Rancho Penasquitos and antennaweb.org says that I need a Medium Directional w/pre-amp. At my location, the two broadcast locations are about 75-80 degrees apart, with Mt. Soledad about 10 miles away and Mt. Miguel about 17-18 miles away, according to a mapping program that I used.
I'm interested in the following feedback from anyone in San Diego, particularly Rancho Penasquitos:
- What antenna are you using?
- How/why did you select this antenna?
- Are you using a pre-amp?
- Is it installed on your chimney or in your attic?
- Where did you buy your antenna?
- Did you have it installed or DIY?
Thanks in advance.
Tom
Sony SAT-T60 DirecTc>ic>Vc>oc> w/2.0.1
Sony SAN-24MD 24" elliptical dish
Thanks in advance.
Tom
