Ok, so I think I was a bone head. But hoping someone can help me out.
I had a 3TB WD green installed in another machine. Instead of partitioning it properly I used the default and then unlocked it with 3TB disk unlocker utility. It basically created two drives, one 2TB and the other about 750GB of the remaining portion.
I liked it because I used the 2TB for media storage and the remaining for downloaded programs and stuff.
Well, I reinstalled my OS and now the drive shows as a 2TB (the data is all there) and then the remaining portion shows as UNALLOCATED.
I can't access the stuff there.
How do I get it back ?
Can I?
Or should I just transfer the data off the 2TB and format it properly as a single TB ??
NOTE: It's full of Blu Ray Rips. Then entire 2TB is full and copying will take a while.
Can I?
