1 - 6 of 6 Posts
I have a Samsung LNT3242hx and have had it for 2 years, just recently it has quit showing picture on any of the inputs but continues to have sound. If I unplug it and plug it in there is blurry picture for a couple of seconds but then it cuts out. I was wondering if anyone knows what might be wrong with it and if it is worth repairing or should I just get a new one. Thanks for the Help
Can you see the Tv menus and osd? Press menu on remote
Is the backlight dropping out?
Do you feel comfortable taking your Tv apart for soldering or board replacement?
Discussion Starter · #3 ·
The Menu does not show up and I don't feel comfortable taking my tv apart. What does backlight dropping mean? When I first turn it on there is a blurry kind of half picture that immediately goes black. Its kind of hard to explain sorry
Could be the Main board ($200), or Power Supply board ($55), or Tcon board ($75), or Inverter board(s) ($75), or Panel ($500). Plus $250-$300 labor.
1 - 6 of 6 Posts
