1 - 4 of 4 Posts
Hey guys recently I have been tempted to go out and buy a new LCD Flat Screen for myself . Unfortunately my knowledge of TVs has become stale so I am reaching out for you guys for help. I'm thinking LCD over Plasma because of life span and what I will be using the TV for. The Screen will be used for Digital Cable use, PC Screen, Xbox 360 and perhaps a few more goodies on the way. Must have atleast 2 HDMI Inputs, 1 or 2 HD components, DVI would be nice but a VGA would be fine. The size I am looking for would be between 40-48inch and the TV with high res 480i/480p/720p/1080i/1080p and a Native Resolution of 1920 x 1080. My price range would be anywhere from 1000-1400 max looking more so in between the two. I am located in Canada so take that into consideration, I have come up with three here but I am open to suggestion because im not entirely sure what to look for.
Sharp:
http://shopper.cnet.com/flat-panel-t...?tag=mncol;lst
LG:
Samsung:
http://shopper.cnet.com/flat-panel-t...-33420967.html
Hopefully you guys can help thanks
One suggestion is to do a forum search on each of those sets so you can view lots of comments on performance and issues with each. That will help you narrow it down
Discussion Starter · #4 ·
Originally Posted by MechanicalMan /forum/post/15582879
Life span? Viera plasma panels are rated at like 100,000 hours.
like I said my knowledge is stale as far as TVs go. And I heard for setting up PC to LCD is better than plasma due to imgage burning
1 - 4 of 4 Posts
