I am installing a map board where I work and I need some advice on a projector. After visiting with Ryan Pream at The City of College Station and actually seeing their dual projector setup, I have decided to install two projectors stacked. One projector will display the top half of the map and the other one will display the bottom half. I work for a small electric utility and our system is about 100 miles North to South and 50 miles West to East. That is why I need the 4:6 ratio. Anyway, my criteria are as follows from most important to least important(but still very important):
1. Resolution (Minimum SXGA)
2. Bulb Life (projector will run 24/7)
3. Price (Maximum $20,000)
4. Screen Door Effect (Could probably live with LCD)
Thanks for you help and another thanks to Ryan for showing us around today.
Jeff
What would you do with a brain if you had one? --Judy Garland
Jeff
