1 - 1 of 1 Posts
I'm looking for a 46/47" LCD TV. I'm leaning towards a LED TV with local dimming so I can get the best black levels, but this is not a requirement. I will be using this TV for gaming, movies and sports. I am on a tight budget and would like to spend less than $1000.
Right now I'm leaning towards a Vizio XVT473SV, but it is a little over my budget at $1300. Currently the best TV I have found under $1000 is the LG 47LE5500 and the 47LE5400 (not really sure what the difference is), but I believe these are edge lit, which I have heard some negative things about.
Any suggestions on any other TV's I should look at? As I mentioned I would like to stay under $1000, but would be willing to go up to $1200 if there is a big step up in quality from the
1 - 1 of 1 Posts
