Hi all, looking for some advice/feedback. I am in the process of building a small home theater. The room is 13' wide by 17' long. The ceiling height is 8'9" except for a small section where there is a soffit which brings the height to 7'11".
The plan is to do a 7.2.4 setup. I will have an acoustically transparent screen with in-wall LCRs behind the screen. The rest of the speakers will also be in-walls.
After doing a ton of research I believe I have narrowed my speaker choices down to Revel and Triad. More specifically here are the speakers I need help choosing between.
Revel
LCR: W990
Surrounds: W783
Triad
LCR: IW Silver/4 LCR
Surrounds: IW Bronze/4
Ignoring cost, can any of you let me know which speakers you think will give me the best sound.
Mike
Revel
LCR: W990
Surrounds: W783
Triad
Mike
