Sorry if this is in the wrong place, I'm not really sure where else it should go.
I'm not very knowledgeable or confident in piecing together a system with separate components so have opted for a bundled set. Below are the two I have landed on, but am unable to tell the difference between them that warrants a £100 price difference.
http://www.richersounds.com/package/system-savers/home-cinema-separates-bundle-deals/pah011898
http://www.richersounds.com/product/speaker-packages/pioneer/htp072/pion-htp072
The cheaper Pioneer one seems more powerful at 600w compared to the 350w of the Yamaha/Tannoy one. Am I understanding this correctly?
Perhaps someone could recommend a different system if neither of these are particularly good. It's going to be used in a smallish bedroom for gaming consoles and PC (movies and music). I would ideally not like to spend more than £350 if possible.
