I am stunned by your question. Neither the Lg OLED C9 or Samsung Q90 are anything close to a value. Both are expensive luxury items. I will be flamed from all sides.
If it's for everyday viewing, mixed usage, the Q90. If you have a dedicated dark room for home theater, the C9. Note: Image retention and burn-in possibilities come with the latter.Need help deciding between the LG C9 OLED and the Samsung QLED Q90 ......
Which one would you guys choose ?
I know there's pros and cons to each and a lot of different variables that go into the decision but which is the better buy for the money ?
I'm just not seeing this. They are comparable models and at the sizes they are available in the US they are comparably priced. Is the 55" Q90 astronomically priced in Europe or something?Depends on the size and usage, but the Q90 is ridiculously expensive for what it is. Like, no way does it need to be that expensive, holy CRAP! It's just because Samsung.
The OLED is the better value for the quality, IMO.
Me either tbh...up here in Canada the 55’s and 65’s are generally comparable in price, but with the 75 and larger sizes the LCD’s are MUCH cheaper.I'm just not seeing this. They are comparable models and at the sizes they are available in the US they are comparably priced. Is the 55" Q90 astronomically priced in Europe or something?
The Samsung tv got last place in every shootout comparing it to the oled and they dont have dolby vison and its extremely overpriced when you consider the fact that its old lcd led tech there is nothing to think about its the oled all the way.
The 75” Q90 is currently ~39% cheaper than the 77” C9! Heck, even the 82” Q90 is still ~17% cheaper than the 77” C9!![]()
Thanks for posting that....very helpful
Good choice. If the LG does Dolby Vision, even better. The one thing that's kept me from considering Sammies is their disdain for DV. Content's going to be advertising DV as a plus so for the price territory, not having it doesn't make sense.Yes i bought the LG E9 this past weekend and absolutely Love it.
Sorry, but bad choice if Motion factors in.....cannot beat any Sony!Good choice. If the LG does Dolby Vision, even better. The one thing that's kept me from considering Sammies is their disdain for DV. Content's going to be advertising DV as a plus so for the price territory, not having it doesn't make sense.
