1 - 2 of 2 Posts
· Registered
Hello people,
I've tried to gather information on the internet, but it seems like it's way harder to understand audio compared to video.
I got 2 Sanyo AD5060 3-way speaker systems and my dad gave me his old Sanyo 2033 receiver. I'm wondering if the speakers are any good? I couldnt find much info on these on google. As for the receiver, it does not really fit my needs since there's only one auxiliary "in", which means I would have to decide between my ps3, xbox or tv to plug in. Unless I'm missing something?
Basically, I'm wondering if these speakers are worth trying and what wo0uld be a good amplifier for them that could run my ps3, xbox and tv? Also, is there a huge difference between a regular av connection and a digital one soundwise? I know you can't get hdmi tv with av cables, but I have no idea how it affects sound.
Thank you and I'm looking forward to your replies.
PS. I posted that same topic at a different place, I just believe the more replies I get the more informed I will be.
· Registered
All of it is junk, don't get your hopes up. What is your budget for an AVR and speakers? You may be able to use those speakers for now but buying a new AVR would make the most sense. You can get all of your sources hooked up getting sound from all.
Speakers don't have to cost a fortune.
What size room do you have? Budget, Music/HT %, etc. Anything that could help us help you.
1 - 2 of 2 Posts
