So I had a few unexpected circumstances arise for me. A little detail.
I have a Mcintosh 8207 but no speakers, I was going to originally get a pair of martin logan ethos, but that will have to be put off for a year or two, maybe longer. In the meantime I have a killer amp, great source (Oppo 105D) and no speakers.
I need to get something affordable that sounds good. 70/30 - music/movies. I'd want to keep my budget under 700.00 so 300-700 range.
I shall only be using this for a 2.1 setup (since I will be using the Oppo's preamp function)
The music I generally listen to are symphonic metal, orchestral/classical, pop (jpop/kpop), rock, techno and occasionally jazz.
The room I am using for now is pretty small 15 x 11 or so, so bookshelves or towers doesn't make a difference, it would probably take up the same amount of space (with stands).
Any suggestions?
Any suggestions?
