  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
need help choosing sub config
325 Views 7 Replies 4 Participants Last post by  indebtbassfreak
help me find a sub :)
1. My budget is around $700, but I don't mind buying one and then saving up for another one for dual subs.
2. Size limit is probably two feet.
3. Room is 2800 cubic sq ft
4. Primary use is HT.
5. I want to hear the rumble when bomb explodes or THUMPS when monsters stomp their feet.
6. Not to concern about appearance.
7. No rush.
See less See more
1 - 8 of 8 Posts
When requesting assistance for a sub purchase several pieces of information are critical in order for people to provide relevant suggestions. Check out this thread for the type of info you'll likely be asked by anyone who replies.
  • Like
Reactions: 1
Also if your drawing is accurate,,,, first thing you will want to do is move the couch forward away from the back wall a couple feet at least (but don't place it in the middle of the room or bass will have nulls). Having it against the back wall can cause a considerable amount of boomyness.
I need some help choosing subwoofers. I attached a picture of the room. Total volume is roughly 2800. My budget currently doesn't allow me to do one giant sub, so I'm thinking about buying one and when the funds are available buy another one.
My first question is what size sub should I go with if its location is right next to the cough (to the left)? 10” 12" or 15"
Second question, which brand? Hsu, Monolith, SVS or Klipsch? All my other speakers Klipsch.
What's your budget? I'm going to go ahead and say don't buy a Klipsch sub.
updated my original post
where would you put the sub?
I would look at the HSU VTF3-MK5 or the Monolith 12" THX Ultra. Both are ported to give you the low end thump for movies, and can be plugged for music if you wish. The Monolith goes on sale sometimes but its also out of stock often.
Most people on the forum will recommend that you buy the best single sub you can afford, and then add a 2nd down the road when budget permits.
For placement do the sub crawl, which is literally crawling around your room while playing bass heavy content and then picking where the bass sounds the best. That's the place to put the sub.
https://www.audioholics.com/home-theater-connection/crawling-for-bass-subwoofer-placement
  • Like
Reactions: 1
PlanetAVS answered your question as i would have. It looks like finding a good spot will be pretty easy in your room. Imo, if one sub to start,,,, i'd be trying to get the sub closer to your front soundstage as opposed to beside your MLP, then if you add a second there are several dual sub configurations that will work including one at the front 1/4 wall and the second at the opposite rear 1/4 wall. But once a second is added do yourself a favor and get set up with REW and measure the response in your room. This will make a pair of ok subs often sound better than a pair of really good subs not properly set up.
You have 15' to your TV so i'd start by pulling your couch at least a foot off the wall maybe two before doing the sub crawl. Don't ever think your going to get it perfectly right the first time, non of us do, so take your time and enjoy the process which is a part of this hobby. You will continue to learn as long as your interest is there and the end result will be worth it.
See less See more
  • Like
Reactions: 1
1 - 8 of 8 Posts
