I’m building a new Home Cinema, with the following specs:
The room is 23.8 ft x 14 ft (7.25 m x 4.25 m)
100% light control
Projector Barco BG1209/2 (700 hours)
Fixed frame screen 120†wide 16:9
I would like to have a 120†(3.0 m) wide screen 16:9 format, but I’m very much in doubt about the choice of screen material. 120†is about the max you can do on a BG1209, so I would think that a high gain would be the right choice but then people are talking about hotspotting and “too much lightâ€.
Whats the problem with too much gain? On a CRT you can lower the output of light and that would only be good for the life of the tubes. Or am I missing something here.
Which screen should I choose?
Henrik Mygind
Dane living in Sweden
100% light control
Henrik Mygind
