I currently have the Channel Master 4228 8-Bay antenna with the Channel Master 7777 Titan2 VHF/UHF Preamplifier with Power Supply installed and have been real happy with it for about a year now. I highly recommend this combination to anyone that cares. Anyway, I'm trying to get prepared for the HD Tivo and would like to add 2 or 3 Channel Master 4221A 4-Bay Bowtie UHF Antennas and combine everything together (this is an attic installation). My local towers are in different directions and I have to frequently use the rotator to lock in on a specific signal.
#1) Can I do this?
#2) What do I need (specifically) to combine the 3 or 4 antenna signals?
#3) I have read the antennas have to be spaced apart somewhat. Is this true?
#4) If I can combine them all, can I run the 1 combined wire into the preamplifier?
I'm assuming you can't use a splitter since I am wanting to combine signals. This is primarily for digital channel reception, but I may splice it to other TV's that don't have digital set top boxes.
Thanks in advance for any help.
#1) Can I do this?
