Status
Not open for further replies.
1 - 3 of 3 Posts
Should I use the digital coaxial output, the digital optical output or the multichannel analog outputs when connecting the Pioneer DV-563 to the Yamaha Rx-V1400?
Richard, the coaxial and optical outputs are for the digital audio formats (Dolby Digital and DTS) while the multichannel analog outputs are for your multichannel audio (SACD and DVD-A).
Your digital outputs can also be used for standard CD listening where you can perform BMgt. in your receiver. If the 1400 has a direct or bypass mode you can utilize that also for possibly better sound.
1 - 3 of 3 Posts
Status
