I just picked up a Loewe Arcada and I love the set, but need to make the VGA input work or I will return it. I tried setting the resolution to 640x480 60Hz as stated in the manual but get nothing but out of sync noise. Has anyone got the computer input working on this set.... I believe the set is configured to work with the RCA STB so if anyone knows what the specs of that signal is I will give it a try.
p.s. I have Powerstrip and have it working on my Toshiba RPTV in the home Theater. This set is for the family room.
Thanks in advance.
Thanks in advance.
