Why not any Denon's?
Originally Posted by tkdee /forum/post/12857304
The Onkyo 605 has a great feature set for the price. The SQ is also pretty good. Maybe not as good as the Marantz though. I would look at what features you need and go from there. If you plan on going surround eventually you may want to look at DTS-MA and TrueHD decoding with HDMI 1.3. From there find the best receiver that fits what you need. If you are choosing between 2 and there is a big price difference, but the more expensive one produces better sound you may come out ahead in buying the poorer sounding one and spending the extra money on better speakers. It seems to be the consensus that while the receiver can make a difference in SQ it is a much lower factor than the speakers.
For what it's worth I bought an Onkyo 605 because it offered almost every feature I'd want and it was only around 400 bucks. I wish it had 1080p-1080p component to HDMI conversion, and 5.1 to 7.1 matrixing but it is what it is.
