1 - 20 of 34 Posts
So i have an htpc its
asrock amd zacate
4gb ddr3 ram
2tb hdd
i have lg blu ray drive
and i have it all plugged in my LG 42inch tv.
Now my problem only is with Playing blueray I have both powerdvd 11 premium from my dad and I bought tmt5. Both in anymovie have a stutter lag in each that is noticeable and cant play movies w/o that stutter and its annoying. Now I am just wondering would adding a ati 5450 into it would i be able to play the movies at full 1080p no problem?
Originally Posted by Darkside /forum/post/20768480
Have you updated the graphics driver?
that might help. i don't have a zacate myself but I have heard that it can play full blu-rays no problem
adding a nicer graphics card would definitely guarantee a fix. just check out assassin's list
Discussion Starter · #6 ·
well i updated the drivers nothing no difference. It plays fine in windowed mode no stuttering nothing. Put it full screen i start to see the stuttering. its very annoying i might just get the i3 2100 i hope that the igp can play blueray if not im picking up a 5450. Im sorry to say I cant get zacate to work i like it but the hassle is giving me just on blueray playback, blueray rip and every other format work fine just this. well i3 2100 here i come.
that is unfortunate that you are having those problems. Personally, I am going to go with the i3 2100 solution soon as well.
Originally Posted by vastolorde /forum/post/0
Yea not sure if i wanna go i3 2100 or get g620 either way planning to get 5450 and i just wanna play blueray in 1080p
Personally I would hold off on the 5450. The 2100 with hd 3000 should have no problem with full blu ray and lossless audio.
Discussion Starter · #10 ·
You sure i tried looking everywhere cause i bought the amd zacate cause i heard it should play blueray and it doesnt. Now if i get a 2100 it should so better wit more cache and speed so in paper it will work but intel graphics rly that good now?
I think if you ask you would get dozens of testimonials here from people who are happily using an i3-2100 for nice smooth blueray playback. Let me be the first.
That's not to say it doesn't have its own quirks and complictions, but I have yet to hear of a solution that doesn't.
I suggest you read the thread here entitled "Official Sandy Bridge / LGA1155 for HTPCs Thread".
Discussion Starter · #14 ·
will do ima be asking which mini itx mobo to get either gigabyte or askrock cause the gigabyte i get $20 cheaper in total but gets horrible reviews. so idk which to get thanks for all your help.
Not sure if this will help you, but I thought I'd throw this out.
I have a htpc with an ATi 5870 graphics card. I use my htpc for both movie watching and game playing. I was getting stuttering while watching live TV, in Media Center.
I looked at my settings in ATI Catalyst Control Center (CCC), and it took me a long time to figure out what was wrong, but here is my solution:
Right click on your desktop, and click on CCC. Go to Video, and Video Settings. Make sure that "Enable Dynamic Contrast" is not selected. Then go click on the "Gaming" tab, and click on "3D Application Settings." For the first 3 options, set them all to "Use application settings."
Once I did this, the stuttering went away. I don't know if this will fix your problem or not. I don't even know if Zacate has the same CCC as a discrete graphics card. But if it does, it's worth a try.
I have played a ripped blu-ray on my zacate with xbmc and it played perfect. I really think you should be able to get it to work, if you can't you might have a hardware problem. Zacate has its weakness, netflix and Hulu HD and a little sluggish in windows, but it does play recorded OTA HD and Blu-ray perfect.
Discussion Starter · #17 ·
Oh no it plays ripped blueray fine.. Im talking about thru the disk. I need it through the disk kinda have a tradition where have friendd come over order pizza and someone brings a blueray movie and we play cards.
1 - 20 of 34 Posts
