1 - 6 of 6 Posts
Hi im new here hope this works but im buying a set of towers from craigslist and this guy say he has Definitive Technology BP2004TL's and Definitive Technology BP20 Supertowers both for the same price. they're both Bi-Polar. which one should i get???
specs BP2004TL's: Two 1 pure aluminum dome tweeter; Two 5-1/4 high definition upper bass/midrange drivers; One 10" cast basket subwoofer per tower
specs BP20:Each tower has four 6 1/2'' drivers and two 1'' tweeters.
so please help what should i buy???
Discussion Starter · #3 ·
What's an MTM setup? And could you just let me know your thoughts on why you would would with the BP20? Thanks for your response.
i suppose i'm in a good situation to answer this as i have bp2004tls and a pair of older bp10s, the model just down from the bp20s. i use the 2004tls as fronts and the bp10s as surrounds currently. the 2004tls have two 5 1/4" mids, two 1" aluminum dome tweeters and 250 watt 10" subs. the bp20s have four 6 1/2" mids and two 1" soft dome tweeters. my bp 10s just have two 6 1/2" mids w/ the two 1" soft dome tweeters.
i made the choice to go w/ the 2004tls up front just b/c of the built in subs. when compared to the bp10s, i like the sound of the built in subs more for ht. now i think it would be different w/ bp20s. you'd probably get much more mid range clarity and as long as you have a capable sub, you wouldn't be missing out on the low end.
another thing to keep in mind is the difference in tweeters. if you go w/ bp20s up front, you'll be hard pressed to find a matching center w/ the same soft dome tweeter. the matching ctr for the 2004tls, the clr 2002, is much easier to find.
if you have the cash, why not buy both pairs?
Discussion Starter · #5 ·
thank you i have a 12 inch infinty sub i think it would handle the low pretty well so you say go with the BP20s for my fronts?
MTM = Mid/woof-Tweeter-Mid/woof orientation of drivers
1 - 6 of 6 Posts
