I have an old AVC-A1SE which has been great, it used to drive a 7.1 system 2 x B&W 604 (s1) (8 ohm); 2 X b&w scm8 (4 ohm); 3 x LCR6 (s2) (8 ohm); ASW 1000;
With a new plasma, we decided to make the move from component to HDMI, we also decided to go from 1 zone (7.1) to 2 zones (5.1 LCR6, ASW1000 and SCM8 and 2 x 604);
I did'nt really want to get rid of the AVC-A1SE, so I thought tha maybe I could use it as a power amp for the 5.1 system and get a new amp...
I ended up with an AVR 2809 as the new amp so I now run Zone 2 off the 2809 (surround back's - assigned amp) and run the pre outs from the 2809 into the AVC-A1SE for zone 1;
It all sort of works apart from the remotes get mixed up (tried to change the remote id - but did'nt work) so when I alter the volume on one amp or change a function/source the other amo changes, even tried blocking the infra red sensor on the avc-a1se.
So my question is... Is there a better way to use my components without spending to much (any more) money?
Cheers
Cheers
