Originally Posted by
molibra /t/1524614/need-help-finding-a-computer-adapter-for-sports-ticker#post_24540387
I need this, but male to male
http://www.newegg.com/Product/Product.aspx?Item=N82E16812296029
Why is it no one makes the male to male?
Because it's weird...
First - that's NOT the same connector type you posted originally. Second, you can always use a "gender changer" pass-through adapter to convert a M/F connector to the opposite one. That's easy and cheap, just not as compact a solution.
What is a good specialty electronic supply store I could try?
Fry's, Altex - there's no "national" chain beyond RadioShack. You'll have to tell us where you're located, then maybe someone will have some local knowledge to guide you further. But honesty, you can get everything you need from one of the Internet stores like markertek, monoprice, parts-express or cablestogo...
