yes, attic mounted antenna can be very effective. but with all ota reception there are variables, distance direction terrain, trees houses etc...
you might start with a small indoor antenna and see how that works. usually radio shack, home depot, lowes, walmart carry antenna locally for you easy to find and return if needed.
then see if you need one up in the attic.
need more info though. what exactly are you using for reception equipment. stb, tv? what channels are you looking for or need the most and are not getting or have trouble with.
