1 - 3 of 3 Posts
Discussion Starter #1
Hi all, sorry if this question has been answered, I'm at work and don't have the time to browse the forum.
I'm looking for an audio solution for my apartment that is small yet produces good sound quality. Ideally it would have 2 speakers (I don't want to have to deal with wires across the room), a sub and an amp. I would hook up the following:
DVD player - HDMI
Cable Box - Standard Red/White cables
Xbox 360 - Optical or Standard Red/White
Also, I would preferrably want it to cost around $400 or less. Does such a system exist, or would I be better off piecing it together with components?
Thanks in advance for your input.
You're looking for a 2.1 system. There used to be several models, but I'm not sure if they're still for sale.
A good receiver (5.1 or 7.1 for a sub output), two quality bookshelfs and a good sub can be had, especially if you go refurb on the receiver.
1 - 3 of 3 Posts
