1 - 5 of 5 Posts
I'm looking to purchase an inexpensive rack or rack system for my HT gear. The rack will be placed in my furnace room so I absolutely could care less what it looks like.
I would prefer an open rack system for maximum ventilation. It needs to hold:
Sound receiver (probably Onkyo 806)
Blu-Ray player (probably Panasonic 35 or similar)
Dish network 622 or similar receiver
room for a couple more sat receiver sized components
Thanks in advance!
DB2
Why not an old server rack - should get them dirt cheap on craigslist...
Example - For 50$
Example - For 50$
That is essentially what I did. My company had an old rack in the dumpster so I ran out with some tools and unbolted the primary rails. I then cut the rails down to size (sawzall) and screwed them into my framed out opening.
If you don't care what it looks like, I might also consider something like this which would be quite well ventilated and plenty of places to route and zip-tie cables. Also, not too expensive:
http://shelving.com/Merchant2/mercha...egory_Code=SMS
1 - 5 of 5 Posts
