Ok I needs some advice before I continue with my networking project.
Right now I have cat5e ran behind my walls going to all of my bedrooms. Each bedroom is terminated with a keystone jack plate that is wired using the T568A diagram. The other end of the Cat5e cable is RJ45 wired with the T568B diagram. The home builder wired the keystone plate and I wired the RJ45. At the time I did not know about trying to keep them the same. The deal is when I plug the RJ45 into my Linksys 160n router I DO get internet connection in all of the jacks with my task manager showing 100mb/s link speed. What I want to know is from what I read on google is that I hooked the ends up wrong by not making them the same termination at ends. I actually made a crossover cable. Is this ok? But like I said everything works.
Now the next question is I plan on installing a gigabyte wireless router and gigabyte switch. Will my setup still work and give me gigabyte speeds? I am waiting for these items to arrive by mail and its killing me wondering if its going to work. If its not going to work I would like to go ahead and rewire the keystone jack plates to T568B and be done. What do you guys/gals think? Should I rewire or everything I have now will work fine? I rather not touch anything since everything works fine now. I'm no electrician and would hate to make things worse. I also read that the switches and routers of today will automatically make the cabling work no matter how its wired. Advice and help please.
