Status
Not open for further replies.
1 - 5 of 5 Posts
Hi I’m having trouble with teaching ‘other’ N.39 commands to my remote Marantz RC5000i.
I have taught all the codes on page 59 of the owner manual successfully except the Command for ‘Positive control for operate’. All the codes on that page works fine except this one. And I do need this one because it’s the discrete code for ON.
I have tried it numerous times and each time I get the following codes:
0000 0067 0000 000c 0006 012c 0006 00c6 0006 00c5 0006 00c6 0006 012c 0006 012b 0006 012b 0006 00c5 0006 012b 0006 012b 0006 012b 0006 0a56
But when I use it NOTHING happens.
I appreciate if anybody can help me with this problem.
Sepehr
Discussion Starter · #3 ·
Yes, it’s a great unit. Actually I have upgraded it to N.390S which is noticeably better than the N.39 I think you should consider it if you have not done it already.
I have contacted madrigal noting yet.
Anybody has that code?
Sepehr
me too....(390S upgrade)...didn't want to brag!!
i use it directly into a power amp with its variable output. minimalist setup; tremendous sound quality.
i also use it as an outboard dac for my satellite receiver.....those digital music stations make for great background music, and the quality on this source is excellent also.
1 - 5 of 5 Posts
Status
