Hey guys. I just bought the components mentioned in the title:
Have:
Athena Micra 5.1 System.
Athena Point 5 MK II.
Onkyo TX-SR606.
Need:
Speaker wire.
Speaker stands.
Dunno what else?
I want to use the center channel speaker from the Point 5 as the center. Then sell or keep the center from the Micras in storage, or would it be a good idea to use it as a rear speaker in my 7.1 setup? If not, I'll use two speakers from the Point 5s and put them in the rear.
Is this the best way to merge the two systems?
Also, I need speaker wire. Does it matter which speaker wire I get? Which gauge would you recommend?
I'm a total newb, so sorry if I'm frustrating with my ignorance!
Any pointers will be greatly appreciated!
Have:
Onkyo TX-SR606.
Need:
Speaker wire.
Speaker stands.
Dunno what else?
