Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
Hi,
I live in San Ramon, CA with Zip code 94582 and at the back of my house is a hill may be 100 ft in height. The following is the information I got from Antennaweb.org using my address. Can you help me to select with HD OTA antenna that I can use? Can I use the small antenna like Winegard SS-2000? Thanks.
Stations and Antenna Types
TV reception is determined by the size and type of antenna and the direction in which it is pointed. To determine the right antenna, use the color coded Antenna Type to select the channels that you wish to view. Antenna types are color coded according to the size and type of antenna needed for reception. The list is arranged in order of ease of reception, with the stations requiring the smallest multidirectional antenna at the top, to those requiring the largest directional antennas at the bottom.
Use the "Compass Orientation" listed below to point your antenna or rotor system for the channels you wish to receive. Please note that "Compass Orientation" is referenced to magnetic North.
The "RF Channel" column is provided to facilitate custom antenna design for special circumstances.
Show All Stations Show Digital Stations Only Show Analog Stations Only
DTV Antenna
Type Call Sign Channel Network City, State Live
Date Compass
Heading Miles
From RF
Channel
* yellow
uhf
KDTV-DT 14.1 UNI SAN FRANCISCO, CA 156° 16.9 51
* yellow
uhf
KICU-DT 36.1 IND SAN JOSE, CA 155° 17.7 36
* yellow
uhf
KTNC-DT 42.1 SPA CONCORD, CA 348° 9.8 14
* yellow
uhf
KSTS-DT 48.1 TEL SAN JOSE, CA 156° 16.9 49
* yellow
uhf
KTEH-DT 54.1 PBS SAN JOSE, CA 155° 17.7 50
* red
vhf
KNTV-DT 11.1 NBC SAN JOSE, CA 248° 28.1 12
blue
uhf
KFTL-CA 28 IND SAN FRANCISCO, ETC, CA 155° 17.7 28
* blue
vhf
KGO-DT 7.1 ABC SAN FRANCISCO, CA 258° 28.8 7
* violet
vhf
KTVJ-LD 36.1 IND SANTA ROSA, CA 276° 38.3 4
Note:
Wing
· Super Moderator
You should post this either in the appropriate local thread, or in HDTV Technical. If you choose the latter, remember to put your CITY and STATE in the thread title.
1 - 3 of 3 Posts
Status
