I have a Kenwood 5900M changer feeding a Denon 4803 receiver. For DVD-Audio I'm of course using the 6-channels outputs and inputs. I'm not sure about the crossover point of the Kenwood but I believe it may be 100 Hz because the manual instructs you to set the main speakers to large if they are capable of handling signals below 100 Hz.
My question is how best to set up my system. The Kenwood allows you to set each speaker to large or normal and the subwoofer to on or off (for 6 channel output). My speakers are Revels so are obviously capable of going below 100 Hz but I suspect it would be best to set them to normal (small).
My Denon receiver is set up with a crossover at 80 Hz, speakers set to small.
What do you recommend?
Craig
Craig
