Need help in the speaker bracket/any other way to mount speakers
274 Views 2 Replies 2 Participants Last post by  RayGuy
2
Hi,
Currently I own Energy take 5, which I will be using as surround and rear speakers until I replace these with nicer/bigger speakers. I have Infinity Primus 363 as my front speakers and Denon 2112CL. I was thinking of getting either full set of infinity or some Energy RC-10 etc. But that apart, I have issue of mounting my surrounds. I think I have very little space and I need some suggestions/recommendations.
I am attaching the pictures.
See less See more
1 - 3 of 3 Posts
Can anyone please recommend any bracket for this? I tried to find brackets which can fit here, I could not find much, also wanted to install the brackets such that I could change the speakers to either Enegy RC-10 or infinity.
Originally Posted by ask_j  /t/1517295/need-help-in-the-speaker-bracket-any-other-way-to-mount-speakers#post_24346601
My only suggestion is to overbuy when you get the brackets. If the speaker is 2 lbs, get a bracket that is rated at 5 lbs, or more. You won't regret overbuying the brackets and you WILL regret underbuying! I speak from experience.
1 - 3 of 3 Posts
