How do you have them crossed? Same frequency range? I have my 24's low-passed at 40hz and my MBMs pick up from there
I had asked Matt about this in the VBSS thread before starting the build, his response was “I'd run them all full range if you can, more sources give you the benefit of response smoothing and increased output over using them in their own separate frequency ranges.” Right now that is how I’m running them.How do you have them crossed? Same frequency range? I have my 24's low-passed at 40hz and my MBMs pick up from there![]()
I would agree with that statement if you're well adapted to get them to play well togetherI had asked Matt about this in the VBSS thread before starting the build, his response was “I'd run them all full range if you can, more sources give you the benefit of response smoothing and increased output over using them in their own separate frequency ranges.” Right now that is how I’m running them.
Thanks for the suggestions. I tried playing with the phase. It did smooth out the 31hz problem, but destroyed everything else. I’m game for giving a try to splitting the sub frequencies. What do you guys recommend for LPF for the marties and HPF for the VBSS’s? Do you use the same frequency and filter for both or overlap them?Its reversing phase at port tune, it's easier to integrate subs ported at the same frequency. Try putting a HP at 40hz like johnson said, make it steep like -48db and see what happens.
How do you have them crossed? Same frequency range? I have my 24's low-passed at 40hz and my MBMs pick up (high passed) from there![]()
