1 - 5 of 5 Posts
Hi,
I am trying to gain control of the lights in my family room, kitchen and dining room. I need 1000w dimmers due to my loads. I want to go with a harmony 1100 if possible. Here is what I now know after some research.
1. Harmony is not z-wave enabled ( as far as I know only the nevo is) The remote needs to control my audio/video as well.
2. The switches are spread out so I don't have line of sight for IR and there is no way to run an IR emitter to the locations.
I looks like the vizia rf would be a good fit but does anyone make a zwave remote like the harmony that does not cost 1k. Or perhaps another dimmer manufacturer that will work.
I also want the capability of doing lighting scenes. Which the vizia can do.
Any advice?
Research Lutron RadioRA2.
Significantly cheaper than 'Classic' RA.
Or look at gettting a URC remote. They can control URC dimmers via RF. The URC dimmers are made by Lutron.
And yes, you can do scenes and IIRC, they come in 1000W models.
1 - 5 of 5 Posts
