hi,I'm using the sa51u projector with my htpc.And I found that my projector have some vertical shadow on the screen(it is hard to see,but you can see it ),I go back to the shop,and try another new sa51u,and got the same result.Did the same thing happens to you?By the way,when you put a full Gray picture on the screen,you may easy to see what I said.
