I personally would hang them using a properly labelled (for weight) molly bolt type thing, but if you really want strength and no worries you should get a nice peice of wood that you can paint or stain, run it horizontally between two studs, and then you can hang your speaker and mount anywhere along the new support beam.
As far as the second question, it depends on how far you want to go. You can get some relatively low key housing to mount to the wall, or you can cut out a couple holes in the wall, one at the speaker level, one down by the baseboard. Then run the wire along the baseboard. Of course if you don't have baseboard this can get tricky....
