Need Help My optoma hd70 will not read my PS3 with HDMI
1227 Views 4 Replies 2 Participants Last post by  MKtheater
I want to upconvert regular dvd's but the optoma hd 70 will not read he PS3 thru the hdmi. It will read it thru the component video but then I can not upconvert dvd's. Anyone have this problem? Can it be my Hdmi cable?
1 - 5 of 5 Posts
It works for me, but the PS3 doesn't upconvert DVDs anyway. Have you activated the HDMI output in the console's settings?
On the PS3 or the Optoma?
On the PS3, there are settings for video output. It will only output one type of video at a time, so if it's set for composite or something besides HDMI, you won't get a picture. Hold the power button for five seconds or so until you hear a beep to reset this. With HDMI connected, turn it on and it should set the video output for HDMI. Then, you choose what you want to use for audio.
Another thing is that you may have to be sure to turn on the projector before you turn on the PS3. I know it works that way with the HD-A1; if I turn that on before the projector, I get an HDMI error in the A1. I haven't tried turning the PS3 on first to see if that's the case with it, but it's possible.
I will try this, Thanks alot.
1 - 5 of 5 Posts
